hub
Newbie level 3
I have a VM-010 Change Machine which can be seen on Ebay. I have a new project that requires removing the solenoid and replace with a relay. The Relay that I am using is an G6RL-1-ASI, which can be found at digikey. The first problem that I had was not being able to get an accurate voltage reading on then solenoid input with a standard volt meter. The readings were all over the place and some time, but not all the times in the negatives. I tested this input with several meters with no success. I did a little research on the solenoid and found that these types are normally 12v or 24v. The bill acceptor in the machine is 12 volt. So I went with the 12 volt relay. Now here is the really interesting part, the relay works. However there is a noticeable vibrating sound that comes from the relay at the time of trigger. I have played with these relays before and normally you only hear a click when activated. The output of the relay goes to the Piface input of a raspberry pi. As long as its only one input the piface will pick it up, however if there are consecutive inputs, say 5 in 3 seconds. The piface can not pick it up, however if I press the button manually 5 times in 3 seconds there is no problem. My question is, do you think there is either something wrong with the relay or I have the wrong voltage or the inputs on the piface just cant pick it up that fast?
