rahulksgift
Newbie level 6
Hi All ,
I have built a solar charger to charge a lithium iron battery
Solar panel I used 5W/8.5 Vpm.
Li-on charger is MC34673.set to 1.A constant current charge .
The issue I'm facing is ,
Solar panel VOC is more than 10 V when there is 100% SUN.But charger IC input over voltage protection limit is 6.8V .When i connect solar panel
with Charger IC , IC it get disabled internally.and there is no charging .
Is it good to connect 6.8V Zener across Panel ?
Or Any other method to regulate solar panel voltage with out much power loss ?
regards,
Aneesh
regards,
Aneesh
