rock94
Junior Member level 3
- Joined
- Apr 12, 2013
- Messages
- 26
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,483
Solar powered car design
I need to design a car which runs off solar power without the use of any other power source.However storing power in components like capacitor is allowed.The motor used is rated for 6v and draws about 1A.One of the challenges is the dark tunnel through which the car must pass while there is no solar energy available.Most of the designs which I looked up online use supercapacitors to hold charge.However I cannot find any capacitors of value above 10000µF locally and cannot order one online since I need to submit the project within 2 days.So is there any way I could design a circuit which can hold a large amount of charge without the use of power sources like batteries.Any suggestions?
Thank you.
Thank you.
