berger.h
Member level 5
I dug up and disassembled the old soil moisture meter
These are two concentric rings made of stainless steel wire, one serving as a transmitting antenna and the other as a receiving antenna.
Distance between antennas of the order of 5cm.
The output is the voltage corresponding to the soil moisture
I tried to draw the electronics wiring
if I'm not mistaken
A 2MHz square wave signal goes to the transmitting antenna 100ns Hi and 400ns Lo.
U1A is clock source 4MHz,
U2A is divder/2
U2B change clock form 50/50 to 25/75
U3A does the same
I don't quite understand the function of U3B, but somehow it compares the signal received by the receiving antenna with the signal from U3A
Its outputs Q and Q / are inverted and converted to analog signal R11, R16 C3, C4 by RC elements
4 pcs of U5 amplifiers then probably convert the signal delay from the receiving antenna back to the way it was transmitted on voltage
The amount of water in the soil around the antennas causes a signal delay, the more water the higher the humidity and the signal delay
In fact, this is a form of TDR (Time Domain Reflectometry)
I was surprised by the relative simplicity.
Questions
What does U3B do?
If anyone could explain the function of individual amplifiers, I would be happy
Time has progressed, I am thinking about how to remake it with a processor.
It is not a problem to use PWM with any pulse width to generate a pulse to the transmitting antenna
The received and transmitted signal could again be "compared" to U3B, converted to voltage on RC and then converted to digital information using internal amplifiers in MCU and ADC, but this is the first idea and you may come up with a better solution.
if I'm not mistaken
U2A is divder/2
U3A does the same
Questions
What does U3B do?
