software switch debounce time???????
d@nny
Full Member level 5
Full Member level 5
hello!
what is the safest time to key debounce?
i am using this technique
key pressed detect
wait 10ms
check state of key
key is pressed = process the data
wait for key released
key released = wait 10ms = returned
is this the safest time or i need to increase it for more accuracy
thanking you in anticipation
10ms seems to be reasonable.
However, the method of keep waitiing in a closed loop, can waste a lot of processing of CPU.
Better to handle it by interruption timming.
You can also use polling using a timer interval so that the code execution doesn't stop while waiting.
If you set a timer to give an interrupt every 10ms then you can read the input and set a flag variable with the button state and then read that flag in the main loop and do the rest.
Alex
Here are a couple of nice links to Ganssle's studies. The first studies the time needed and gives data.
The second gives some software advice.
Debouncing
Debouncing
John
