mcmsat13
Member level 5
I am experimenting with this 28Pins PIC PIC16F886 as a beginner and got confused somewhere.
If a start the PWM module , in this case CPP1, the device will get hanged and will not work again. Initially I thought it is software simulation issue but to my surprise I found out that it is the same thing on the Hardware Simulation.
If I compile the code with PWM settings and without the interrupt Timer Delays, it will work and I compile without the PWM it will also work. So now I need help regarding the relationship between the CPP PWM and Interrupt Timer Delay. Are there things I am missing in the code please?
I work with CCS C and I will post the circuit and the Code below.
View attachment 16F886.rar
#include <16F886.h>
#device ADC = 10
#FUSES NOWDT,HS,PUT,NOPROTECT,NOMCLR,NOCPD NOBROWNOUT,NOIESO,FCMEN,
#FUSES NOLVP,NOWRT,
#use delay(clock = 8000000)
#define HIGH_START 0xFF -250 //500us INT_RTCC
#define SYS PIN_B2
#define MS_ON PIN_B4
#define RL1 PIN_C6
#define MOK PIN_C7
#define BEEPER PIN_B6
#define CHG_CTR PIN_B7
short TabPos,ResetFlag;
short DL2_5s,SDL2_5s;
long MS,CDL2_5s,Counter_sys_1s,Counter_1s,Counter_5s;
const unsigned char PW_Tab[71]= {
0,10,20,30,41,51,61,71,82,92,102,112,123,133,143,153,164,174,184,194,205,
215,225,235,246,256,266,276,286,297,307,317,327,338,348,358,368,379,
389,399,409,420,430,440,450,461,471,481,491,502,512,522,532,543,553,
563,573,584,594,604,614,624,635,645,655,665,676,686,696,706};//70%
void init(void) // Hardware initialization
ResetFlag=0;
setup_oscillator(OSC_8MHZ | OSC_INTRC);
setup_adc(ADC_CLOCK_DIV_32); // 8Tosc ADC conversion time
setup_adc_ports(sAN9); // Select Analog Inputs
setup_ccp1(CCP_PWM); // Configure CCP1 as standard PWM
setup_timer_2(T2_DIV_BY_16,255,1); // Set PWM frequency to 488Hz?
set_pwm1_duty(0L);
setup_comparator(NC_NC_NC_NC); // disable comparator module
set_rtcc(HIGH_START);
setup_counters(RTCC_INTERNAL, RTCC_DIV_4);
enable_interrupts(INT_RTCC);
enable_interrupts(global);
SDL2_5s=false;
DL2_5s=false;
// the timer is incremented (8000000/4)/4 or 500000 times a sond (2 us).
// 250 x 2us = 500us
#INT_RTCC
void clock_isr(void)
if (SDL2_5s)
if (++CDL2_5s>=(5000*2))
SDL2_5s=false;
DL2_5s=true;
else CDL2_5s=0;
if (++Counter_SYS_1s>=(1000*2))
Counter_sys_1s=0;
output_toggle(SYS);
if (input_state(MOK)==1)
if (++Counter_1s >=(1000*2))
Counter_1s=0;
output_low(BEEPER);
if (++Counter_5s >=(5000*2))
Counter_5s=0;
output_high(BEEPER);
void main (void)
init(); // Configure peripherals/hardware
while(1)
/////////MS Settings/////////MS Settings/////////MS Settings/////////
set_adc_channel(9); // Select channel AN9
delay_ms(1); // Wait 1ms
MS = read_adc(); // Read from AN9 and store in MS
if(MS >= 84 && MS <= 177) // >= 0.410V && <= 0.864V // >= 140V & <=250V
SDL2_5s=true; // 15 seconds delay before MS Changeover
if(DL2_5s)
output_high(MS_ON);
DL2_5s=false;
else SDL2_5s=false;
if(MS <= 53 || MS >= 258)// <= 0.260V || >=1.26V// Below <= 120V and >= 276V
output_low(MS_ON);// MS is not within usable range
output_low(RL1);
if (input_state(MOK)==0)
output_high(RL1);
if (input_state(CHG_CTR)==1 && ResetFlag) // PWM Starts
ResetFlag=0;
for (TabPos=0;TabPos<=10;++TabPos)
set_pwm1_duty(PW_Tab[TabPos]);
delay_ms(50); // =3 sec
if (input_state(CHG_CTR)==0) // PWM Stops
ResetFlag=1;
set_pwm1_duty(0L);
