Snubber circuit design
www111
Junior Member level 3
Hi all,
I want to control (switch on/off) inductive motor(230Vac) via relay, and I should use a snubber circuit to suppress Voltage transients.
Do I have to connect the snubber across the relay contact or across the motor contacts (if across the motor , do I have to use 1 snubber(RC) per induktor coil?), and do I still need to use a protection diode for the relay across the contacts?
Best Regards
