Electro nS
Full Member level 6
- Joined
- Mar 9, 2013
- Messages
- 324
- Helped
- 49
- Reputation
- 98
- Reaction score
- 48
- Trophy points
- 1,308
- Activity points
- 3,818
dear guys i am running BIG DC motor from a relay
the relay is acting weirdly after some uses , it gets stuck and needs to be switched on and off several times to run again . some times i hit the relay in order to work !! i have 2 theories for this problem : 1- relay is bad quality (chinease ) and is losing most of its life while soldering it at high temperature to the PCB !
2- the spikes from inductive load are killing it
please advise from your knowledge and experience which is the most likely to happen ?
i attached a block diagram of the circuit , i have capacitor across the motor and i am using a 100ohm resistor across the relay to precharge the bulk capacitor before turning on the system !
the block in the red is my thoughts of solution for the problem , A capacitor or a reverse diode across the relay contact .
Note : the relay coil (0.1A) (is being switched by npn darlington from uC and is well protected )
