snm calculation of sram array
hello
i want simulation sram in hspice
but i dont know
please please help me for netlist and calculate SNM
but i dont know
This is a 2-month old thread.Maybe better to start a new thread.
I used to do SRAM simulations in T-Spice.But do you have library files? & which length are you working on ?
Do you know about butterfly curves ?
A sample code on which you can work:
*[B]CODE-SPICE[/B]
.lib "E:\Stuff\NG Spice\SPICE PROGRAMS\BTP\45 nominal.md"
.GLOBAL VDD
.PARAM VDD=0.6V
.options list post
*.temp 100
.PARAM U=0
.PARAM UL='-VDD/sqrt(2)'
.PARAM UH='VDD/sqrt(2)'
.PARAM BITCAP=1E-12
MPL QD QB VDD VDD PMOS W=45n L=45n AS=40.5f PS=1.89u AD=40.5f PD=1.89u
MNL QD QB GND GND NMOS W=90n L=45n AS=81f PS=1.98u AD=81f PD=1.98u
MPR QBD Q VDD VDD PMOS W=50n L=45n AS=162f PS=2.16u AD=162f PD=2.16u
MNR QBD Q GND GND NMOS W=90n L=45n AS=81f PS=1.98u AD=81f PD=1.98u
MAL BLB WL QBD GND NMOS W=45n L=45n AS=40.5f PS=1.89u AD=40.5f PD=1.89u
MAR BL WL QD GND NMOS W=45n L=45n AS=40.5f PS=1.89u AD=40.5f PD=1.89u
VVDD VDD GND DC=VDD
*****Read****
*VWL WL GND PULSE(1 0 0n 1n 1n 30n 1200n)
*.IC V(BL)=VDD
*.IC V(BLB)=VDD
*****Hold****
VWL WL GND DC=0v
.IC V(BL)=VDD
.IC V(BLB)=VDD
*****Write***
*VBL BL GND PULSE (0 1 0n 5n 5n 40n 100n)
*VBLB BLB GND PULSE (1 0 0n 5n 5n 40n 100n)
*VWL WL GND PULSE(0 1 0n 1n 1n 75n 200n)
CBLB BLB 0 BITCAP
CBL BL 0 BITCAP
EQ Q 0 VOL='1/sqrt(2)*U+1/sqrt(2)*V(V1)'
EQB QB 0 VOL='-1/sqrt(2)*U+1/sqrt(2)*V(V2)'
EV1 V1 0 VOL=' U + sqrt(2)*V(QBD)'
EV2 V2 0 VOL='-U + sqrt(2)*V(QD)'
EVD VD 0 VOL='ABS(V(V1) - V(V2))'
.DC U UL UH 0.01
*.tran 0.5n 500n
*.PRINT DC V(QD) V(QBD) V(QB) V(Q) V(V1) V(V2)
.PRINT DC V(QB) V(QBD)
*.print tran V(BL) V(BLB)
.MEASURE DC MAXVD MAX V(VD)
.MEASURE DC SNM param='1/sqrt(2)*MAXVD'
.END
hello thanks alot.
i have 32nm technology
i am a student and i dont know working with hspice for butterfly curves.
excuse me
hi
i simulated this netlist and no error
but i dont know about it
hi
Did you change this line in the code that i posted :
to the location on your pc where your 32 nm library file is located
So it would look like this:
.lib "..your library path..\library file name"
and also change the L=45n in the following lines to 32n:
Code dot - [expand]
By don't know about it,do you mean not able to understand it ? Are you getting butterfly curves ?
Butterfly curves look like this:
i simulated that netlist but can not see Butterfly curves in CosmosScope
for example in read operation read:
.IC V(BL)=VDD
.IC V(BLB)=VDD
Did you see the waveform that i attached in post #7.You need to have v(QB) & v(QBD) in the same plot.
and in your post #6 you have mentioned the following code:
.IC V(BL)=VDD
.IC V(BLB)=VDD
If you've simulated exactly as per my code,you are driving WL from 1 to 0 & Vdd is only 0.6,so i suggest you to change the value of Vdd to 1 as well.
changes in my code:-
.GLOBAL VDD
.PARAM VDD=0.6V
hello
why ?
if they are changing with :
mosn1              Q          QB            0                0         nmos      l=32n   w=90n
mosp2              Q          QB          vdd            vdd       pmos      l=32n   w=50n
mosn3              QB        Q              0                0         nmos      l=32n   w=90n
mosp4              QB        Q            vdd            vdd       pmos      l=32n   w=50n
mosn5              BL         WL           QB             0         nmos      l=37n   w=47n
mosn6              BLB       WL           Q               0         nmos      l=37n   w=47n
what happend??
Hi samira,
what happend??
Your pass transistors,why do they have a channel length of 37n,don't change the length,try only changing the width of transistors.You are using 32nm library,so keep length fixed at 32n
Also why does your code not have other mos parameters like area etc.. apart from length & width,like my code has.
Your pass transistors are also wrongly connected.Modify your code to the below code:
mosp2            Q         QB       vdd         vdd   pmos      l=32n   w=45n
[B]mosn5        BLB     WL          QB          0         nmos      l=32n   w=32n
mosn6             BL       WL          Q            0         nmos      l=32n   w=32n [/B]
Now with the above code,plot Q & QB in same plot to get butterfly curve
helllo
excuse me for my alots question
when i simulated in read mode i see:
helllo
From your attached waveform,it seems you Vdd = 0.6 V,can you increase it to 1V & post the simulation waveform.
And can you do hold waveform also? I've seen from my simulations that you get better hold waveforms than read.
Most probably,your vdd = 0.6 is less than threshold voltage(vth =0.7) ? are you looking for sub-threshold operation ?
hi
when we explanation noise voltage source for read and write operation??
hi
What do you mean ? I can't understand what you're saying.
Did you do the changes i suggested in post #13,by changing Vdd from 0.6 V to 1 V ? Are you doing sub-threshold design ?
hello
why HOLD SNM and WRITE SNM are similar???
HOLD SNM = 0.2242
READ SNM = 0.1358
WRITE SNM = 0.2243
please help me please.
    Prashil@03
