sms recieving problem with SIM300
Jestin Kuriakose
Newbie level 6
Newbie level 6
I am working on a embedded project using GSM SIM300.i am using Atmel at89s52, GSM module ,temperature sensor LM35.
Working of project- Temp sensor will sense the temperature and sent a message to my cell phone only if the temperature is above 30^c,,and if i sent a SMS to the cell phone(for eg-OK),the relay connected to the microcontroller should turn ON.My code is as follows-
#include<reg51.h>
#include<stdio.h>
#define MYDATA P1;
sbit ALE=P2^4;
sbit OE=P2^5;
sbit SC=P2^6;
sbit EOC=P2^7;
sbit ADDR_A=P2^0;
sbit ADDR_B=P2^1;
sbit MOTOR=P2^2;
unsigned char rx[20],msg[6];
unsigned char sensor1,adc1,r;
void clear(void)
unsigned char r;
for(r=0;r<100;r++)
rx[r]=0x00;
void clear1(void)   //user msg
unsigned char n;
for(n=0;n<=5;n++)
msg[n]=0x00;
void serialcomm()
 TMOD=0x20;        // Mode=2
 TH1=0xfd;         // 9600 baud
 SCON=0x50;        // Serial mode=1 ,8-Bit data,1 Stop bit ,1 Start bit  , Receiving on
 TR1=1;           // Start timer
void delay(unsigned int value)
     unsigned int i,j;
     for(i=0;i<value;i++)
     for(j=0;j<1275;j++);
void serial(unsigned char x)
	SBUF=x;
	while(TI==0);
	TI=0;
void Send2Gsm(char *aaa)
     while(*aaa!='\0')
			 serial(*aaa);
			 aaa++;
unsigned char convert(void)
{	unsigned char value;
	delay(1);
	ALE=1;
	delay(1);
	SC=1;
	delay(1);
	ALE=0;
	SC=0;
	while(EOC==1);
	while(EOC==0);
	OE=1;
	delay(1);
	value=MYDATA;
	OE=0;
	return(value);
void receive_data()  interrupt 4     // Function to recieve data serialy from RS232 into uc
 unsigned char r;
  rx[r]=SBUF;                       // Read sbuf
  RI=0;
void main()
	char string1[10};
	int temp;
  serialcomm();
  Send2Gsm("AT\r\n");
  delay(2);
  Send2Gsm("AT+CMGF=1\r\n");
  delay(2);
  Send2Gsm("AT+CMGS= +918762357075\r\n");
  delay(2);
  Send2Gsm("hello");
  serial(0x1a);
  while(1)
  ADDR_B=0;
	ADDR_A=0;
	sensor1=convert();
	if(sensor1>60 )
		temp=(adc1*0.489);
		sprintf(string1,"%d",temp);
                delay(500);
		Send2Gsm("Temperature=");
		Send2Gsm(string1);
		Send2Gsm("*c");
                delay(500);
		serial(0x1A);
		delay(500);
		IE=0x90;
		while(rx[r]=='?')
     IE=0x00;   //disable interrupt
     if(rx[0]=='*' && rx[1]=='O' && rx[2]=='N' )
     MOTOR=1;
     clear();
     clear1();
   else if(rx[0]=='*' && rx[1]=='O' && rx[2]=='F')
       MOTOR=0;
       clear();
       clear1();
i am not getting output with this code.i am having doubt with the recieving sms to the gsm modem.can anyone point out the mistakes in my code ??
you appear to send CTRL/Z
  serial(0x1a);
before the Temperature, etc which would terminate the message
do you received the "hello" part of the message
Try this
PHP:
  Send2Gsm("AT\r");
  delay(2);
  Send2Gsm("AT+CMGF=1\r");
  delay(2);
  Send2Gsm("AT+CMGS=\"+918762357075\"\r");
  delay(2);
I have used this in my program and it'sworkimg for sending msg
still not working.should we give at command ATE0 at the beginning to avoid echo from the gsm.
Also,should we connect the ground of gsm modem to ground of microcontroller (my friend told me this). i have given supply to gsm modem.so, no need to do it right ?
