hasmibaih
Junior Member level 2
- Joined
- Dec 7, 2013
- Messages
- 23
- Helped
- 1
- Reputation
- 2
- Reaction score
- 0
- Trophy points
- 8
- Activity points
- 286
HI,
i try to sending sms with SIM900 through Mikrokontroller.
but it can't send sms
this is my code :
i had try to using interupt for checking reply from SIM 900, but SIM 900 didn't replay anything
so i checking SIM900 with HyperTerminal, but i can sending sms, SIM900 is ok
so where is my problem ? code or anything else ?
help me please
thanks
this is my code :
This program was produced by the
CodeWizardAVR V2.05.3 Standard
Automatic Program Generator
© Copyright 1998-2011 Pavel Haiduc, HP InfoTech s.r.l.
http://www.hpinfotech.com
Project :
Version :
Date : 1/10/2014
Author : hasmi baih
Company : zzz
Comments:
Chip type : ATmega162
Program type : Application
AVR Core Clock frequency: 11.059200 MHz
Memory model : Small
External RAM size : 0
Data Stack size : 256
#include <mega162.h>
#include <delay.h>
// Alphanumeric LCD functions
#include <alcd.h>
#ifndef RXB8
#define RXB8 1
#endif
#ifndef TXB8
#define TXB8 0
#endif
#ifndef UPE
#define UPE 2
#endif
#ifndef DOR
#define DOR 3
#endif
#ifndef FE
#define FE 4
#endif
#ifndef UDRE
#define UDRE 5
#endif
#ifndef RXC
#define RXC 7
#endif
#define FRAMING_ERROR (1<<FE)
#define PARITY_ERROR (1<<UPE)
#define DATA_OVERRUN (1<<DOR)
#define DATA_REGISTER_EMPTY (1<<UDRE)
#define RX_COMPLETE (1<<RXC)
// USART0 Receiver buffer
#define RX_BUFFER_SIZE0 8
char rx_buffer0[RX_BUFFER_SIZE0];
#if RX_BUFFER_SIZE0 <= 256
unsigned char rx_wr_index0,rx_rd_index0,rx_counter0;
#else
unsigned int rx_wr_index0,rx_rd_index0,rx_counter0;
#endif
// This flag is set on USART0 Receiver buffer overflow
bit rx_buffer_overflow0;
// USART0 Receiver interrupt service routine
interrupt [USART0_RXC] void usart0_rx_isr(void)
char status,data;
status=UCSR0A;
data=UDR0;
[COLOR="#B22222"]lcd_putsf("1");[/COLOR] //interupt
if ((status & (FRAMING_ERROR | PARITY_ERROR | DATA_OVERRUN))==0)
rx_buffer0[rx_wr_index0++]=data;
#if RX_BUFFER_SIZE0 == 256
// special case for receiver buffer size=256
if (++rx_counter0 == 0) rx_buffer_overflow0=1;
#else
if (rx_wr_index0 == RX_BUFFER_SIZE0) rx_wr_index0=0;
if (++rx_counter0 == RX_BUFFER_SIZE0)
rx_counter0=0;
#endif
#ifndef _DEBUG_TERMINAL_IO_
// Get a character from the USART0 Receiver buffer
#define _ALTERNATE_GETCHAR_
#pragma used+
char getchar(void)
char data;
while (rx_counter0==0);
data=rx_buffer0[rx_rd_index0++];
#if RX_BUFFER_SIZE0 != 256
if (rx_rd_index0 == RX_BUFFER_SIZE0) rx_rd_index0=0;
#endif
#asm("cli")
--rx_counter0;
#asm("sei")
return data;
#pragma used-
#endif
// USART1 Receiver buffer
#define RX_BUFFER_SIZE1 8
char rx_buffer1[RX_BUFFER_SIZE1];
#if RX_BUFFER_SIZE1 <= 256
unsigned char rx_wr_index1,rx_rd_index1,rx_counter1;
#else
unsigned int rx_wr_index1,rx_rd_index1,rx_counter1;
#endif
// This flag is set on USART1 Receiver buffer overflow
bit rx_buffer_overflow1;
// USART1 Receiver interrupt service routine
interrupt [USART1_RXC] void usart1_rx_isr(void)
char status,data;
status=UCSR1A;
data=UDR1;
rx_buffer1[rx_wr_index1++]=data;
#if RX_BUFFER_SIZE1 == 256
if (++rx_counter1 == 0) rx_buffer_overflow1=1;
#else
if (rx_wr_index1 == RX_BUFFER_SIZE1) rx_wr_index1=0;
if (++rx_counter1 == RX_BUFFER_SIZE1)
rx_counter1=0;
#endif
// Get a character from the USART1 Receiver buffer
#pragma used+
char getchar1(void)
char data;
while (rx_counter1==0);
data=rx_buffer1[rx_rd_index1++];
#if RX_BUFFER_SIZE1 != 256
if (rx_rd_index1 == RX_BUFFER_SIZE1) rx_rd_index1=0;
#endif
#asm("cli")
--rx_counter1;
#asm("sei")
return data;
#pragma used-
// Write a character to the USART1 Transmitter
#pragma used+
void putchar1(char c)
while ((UCSR1A & DATA_REGISTER_EMPTY)==0);
UDR1=c;
#pragma used-
// Standard Input/Output functions
#include <stdio.h>
// Declare your global variables here
void main(void)
// Declare your local variables here
// Crystal Oscillator division factor: 1
#pragma optsize-
CLKPR=0x80;
CLKPR=0x00;
#ifdef _OPTIMIZE_SIZE_
#pragma optsize+
#endif
// Input/Output Ports initialization
// Port A initialization
// Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T
PORTA=0x00;
DDRA=0x00;
// Port B initialization
PORTB=0x00;
DDRB=0x00;
// Port C initialization
PORTC=0x00;
DDRC=0x00;
// Port D initialization
PORTD=0x00;
DDRD=0x00;
// Port E initialization
// Func2=In Func1=In Func0=In
// State2=T State1=T State0=T
PORTE=0x00;
DDRE=0x00;
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: Timer 0 Stopped
// Mode: Normal top=0xFF
// OC0 output: Disconnected
TCCR0=0x00;
TCNT0=0x00;
OCR0=0x00;
// Timer/Counter 1 initialization
// Clock value: Timer1 Stopped
// Mode: Normal top=0xFFFF
// OC1A output: Discon.
// OC1B output: Discon.
// Noise Canceler: Off
// Input Capture on Falling Edge
// Timer1 Overflow Interrupt: Off
// Input Capture Interrupt: Off
// Compare A Match Interrupt: Off
// Compare B Match Interrupt: Off
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// Timer/Counter 2 initialization
// Clock value: Timer2 Stopped
// OC2 output: Disconnected
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// Timer/Counter 3 initialization
// Clock value: Timer3 Stopped
// OC3A output: Discon.
// OC3B output: Discon.
// Timer3 Overflow Interrupt: Off
TCCR3A=0x00;
TCCR3B=0x00;
TCNT3H=0x00;
TCNT3L=0x00;
ICR3H=0x00;
ICR3L=0x00;
OCR3AH=0x00;
OCR3AL=0x00;
OCR3BH=0x00;
OCR3BL=0x00;
// External Interrupt(s) initialization
// INT0: Off
// INT1: Off
// INT2: Off
// Interrupt on any change on pins PCINT0-7: Off
// Interrupt on any change on pins PCINT8-15: Off
MCUCR=0x00;
EMCUCR=0x00;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=0x00;
ETIMSK=0x00;
// USART0 initialization
// Communication Parameters: 8 Data, 1 Stop, No Parity
// USART0 Receiver: On
// USART0 Transmitter: On
// USART0 Mode: Asynchronous
// USART0 Baud Rate: 115200
UCSR0A=0x00;
UCSR0B=0x98;
UCSR0C=0x86;
UBRR0H=0x00;
UBRR0L=0x05;
// USART1 initialization
// USART1 Receiver: On
// USART1 Transmitter: On
// USART1 Mode: Asynchronous
// USART1 Baud Rate: 115200
UCSR1A=0x00;
UCSR1B=0x98;
UCSR1C=0x86;
UBRR1H=0x00;
UBRR1L=0x05;
// Analog Comparator initialization
// Analog Comparator: Off
// Analog Comparator Input Capture by Timer/Counter 1: Off
ACSR=0x80;
// SPI initialization
// SPI disabled
SPCR=0x00;
// Alphanumeric LCD initialization
// Connections are specified in the
// Project|Configure|C Compiler|Libraries|Alphanumeric LCD menu:
// RS - PORTC Bit 0
// RD - PORTC Bit 1
// EN - PORTC Bit 2
// D4 - PORTC Bit 4
// D5 - PORTC Bit 5
// D6 - PORTC Bit 6
// D7 - PORTC Bit 7
// Characters/line: 8
lcd_init(16);
// Global enable interrupts
#asm("sei")
lcd_clear();
putchar(13);
delay_ms(300);
putchar(13);
delay_ms(300);
putchar(13);
delay_ms(300);
lcd_putsf("SMS Gateway");
printf("AT");
putchar(13);
delay_ms(300);
printf("AT+CMGF=1");
putchar(13);
delay_ms(300);
printf("AT+CMGS=\"085730700750\"");
putchar(13);
delay_ms(300);
printf("yes bisa");
delay_ms(300);
putchar(26);
putchar(13);
lcd_gotoxy(0,1);
lcd_putsf("done");
delay_ms(300);
while (1)
// Place your code here
help me please
thanks
