chitobuknoy18
Junior Member level 1
can anyone help my project regarding sms controller using SE t230 with pic16f877a that control relays (8 relays) here is my code below:
#define TRIGGER PORTD.F1 // set porta/f5 as output
#define DATA PORTA.F4 // set data to c922 for keypad decoding
unsigned int index=0,count=0,address=0,addrLength=247,inbox=0,intFlag=0;
unsigned short intTimer;
unsigned char msg[30], mess[20];
void ATOpen()
Usart_Write('A');
Usart_Write('T');
Usart_Write(0x0D);
void changeCharacterSetting()
Usart_Write('A');
Usart_Write('T');
Usart_Write('+');
Usart_Write('C');
Usart_Write('S');
Usart_Write('C');
Usart_Write('S');
Usart_Write('=');
Usart_Write('"');
Usart_Write('8');
Usart_Write('8');
Usart_Write('5');
Usart_Write('9');
Usart_Write('-');
Usart_Write('1');
Usart_Write('"');
Usart_Write(0x0D);
void textMode() { // Set message format as textmode
Usart_Write('A');
Usart_Write('T');
Usart_Write(0x0D);
delay_ms(500);
Usart_Write('A');
Usart_Write('T');
Usart_Write('+');
Usart_Write('C');
Usart_Write('M');
Usart_Write('G');
Usart_Write('F');
Usart_Write('=');
Usart_Write('1');
Usart_Write(0x0D);
delay_ms(500);
void phoneMem() { // Set preferred message storage as Phone Memory
Usart_Write('A');
Usart_Write('T');
Usart_Write('+');
Usart_Write('C');
Usart_Write('P');
Usart_Write('M');
Usart_Write('S');
Usart_Write('=');
Usart_Write('"');
Usart_Write('M');
Usart_Write('E');
Usart_Write('"');
Usart_Write(0x0D);
delay_ms(500);
void ckpd() { // Received read message
Usart_Write('A');
Usart_Write('T');
Usart_Write('+');
Usart_Write('C');
Usart_Write('K');
Usart_Write('P');
Usart_Write('D');
Usart_Write('=');
Usart_Write('1');
Usart_Write(0x0D);
void readMsg() { // Received read message
Usart_Write('A');
Usart_Write('T');
Usart_Write('+');
Usart_Write('C');
Usart_Write('M');
Usart_Write('G');
Usart_Write('R');
Usart_Write('=');
Usart_Write('1');
Usart_Write(0x0D);
void delMsg() { // Delete message for preferred message memory
Usart_Write('A');
Usart_Write('T');
Usart_Write('+');
Usart_Write('C');
Usart_Write('M');
Usart_Write('G');
Usart_Write('D');
Usart_Write('=');
Usart_Write('1');
Usart_Write(0x0D);
delay_ms(500);
void check_message() { // check message status
if(strcmp(mess,"on")==0)
int extract_message(){ // extract the message from the cellphone
int x=0,y=0,flag=1;
char a;
inbox=0;
readMsg();
while(x!=10000){
if(Usart_Data_Ready()){
y++;
a=Usart_Read();
if(a=='r'||a=='R'){
flag=0;
break;
if(y>=70){
if(a!='O' && a!='K' && isalpha(a)){
msg[inbox++]=a;
x++;
return flag;
void SMSProcess(){ // SMS processing routine
int message_index=0;
if(extract_message()==1){
for(message_index=0;message_index<inbox;message_index++){
if(isalpha(msg[message_index]))
mess[message_index]=msg[message_index];
mess[message_index]='\0';
check_message();
delMsg();
delay_ms(250);
void interrupt()
intTimer++;
PIR1.TMR1IF=0;
if(intTimer%20==0){
intFlag=1;
void main()
delay_ms(200);
TRISC.F6 = 0; //set direction of PORTC6 as output -- TX -- transmitter
TRISC.F7 = 1; //set direction of PORTC7 as input -- RX -- reciever
TRISD.F1 = 0; // set direction of PORTB0 as input -- external interrupt connected to the motion detecto
delay_ms(4000);
PORTD.F1 = 1;
Usart_Init(9600); //initializes baud rate at 9600 bits per second
delay_ms(400);
textMode();
phoneMem();
SMSProcess();
readMsg();
ckpd();
_______________________________
pls help me
void ATOpen()
Usart_Write('A');
Usart_Write('T');
Usart_Write(0x0D);
Usart_Write('A');
Usart_Write('T');
Usart_Write('+');
Usart_Write('C');
Usart_Write('S');
Usart_Write('C');
Usart_Write('S');
Usart_Write('=');
Usart_Write('"');
Usart_Write('8');
Usart_Write('8');
Usart_Write('5');
Usart_Write('9');
Usart_Write('-');
Usart_Write('1');
Usart_Write('"');
Usart_Write(0x0D);
Usart_Write('A');
Usart_Write('T');
Usart_Write(0x0D);
delay_ms(500);
Usart_Write('A');
Usart_Write('T');
Usart_Write('+');
Usart_Write('C');
Usart_Write('M');
Usart_Write('G');
Usart_Write('F');
Usart_Write('=');
Usart_Write('1');
Usart_Write(0x0D);
delay_ms(500);
Usart_Write('A');
Usart_Write('T');
Usart_Write('+');
Usart_Write('C');
Usart_Write('P');
Usart_Write('M');
Usart_Write('S');
Usart_Write('=');
Usart_Write('"');
Usart_Write('M');
Usart_Write('E');
Usart_Write('"');
Usart_Write(0x0D);
delay_ms(500);
Usart_Write('A');
Usart_Write('T');
Usart_Write('+');
Usart_Write('C');
Usart_Write('K');
Usart_Write('P');
Usart_Write('D');
Usart_Write('=');
Usart_Write('1');
Usart_Write(0x0D);
Usart_Write('A');
Usart_Write('T');
Usart_Write('+');
Usart_Write('C');
Usart_Write('M');
Usart_Write('G');
Usart_Write('R');
Usart_Write('=');
Usart_Write('1');
Usart_Write(0x0D);
Usart_Write('A');
Usart_Write('T');
Usart_Write('+');
Usart_Write('C');
Usart_Write('M');
Usart_Write('G');
Usart_Write('D');
Usart_Write('=');
Usart_Write('1');
Usart_Write(0x0D);
delay_ms(500);
int x=0,y=0,flag=1;
char a;
inbox=0;
readMsg();
while(x!=10000){
y++;
a=Usart_Read();
if(a=='r'||a=='R'){
flag=0;
break;
if(y>=70){
msg[inbox++]=a;
x++;
return flag;
check_message();
delMsg();
delay_ms(250);
void interrupt()
intTimer++;
PIR1.TMR1IF=0;
if(intTimer%20==0){
intFlag=1;
void main()
delay_ms(200);
delay_ms(4000);
PORTD.F1 = 1;
delay_ms(400);
textMode();
phoneMem();
SMSProcess();
readMsg();
ckpd();
pls help me
