as usually i'm stucked in my project again. So definitily in need of your help.
I'm doing a project regarding control switches through sms messaging. I found some circuit diagrams to connect AT supported mobile to the PIC 16f877a. but i have no idea how to write codes to program the pic to access the message memory and decode them. ((( simply, how to insert AT commands to the SC. (so far i was using PIC BASIC pro to program ICs. But it seems now onwards i will have to use C.)
AT Comands are sent through serial UART, so u have to learn the AT comands <
The mObile or gsm, module would be connected through Rx Tx and u have to send ur comands as u would send any string from the Microcontroller,
For example if you send the AT comand AT+CMGR=1\r in most of modules to read the message that is stored at location 1; so u can send this comand in code as
UART_send_string("AT+CMGR=1\r");
---------- Post added at 07:46 ---------- Previous post was at 07:43 ----------
Thanks a lot sherazi. still have some problems. when i type UART in mikro C it says undeclared identifier. So, is there any other way of sending UART pattern signals in Mikro C?
