papaisou11
Member level 2
Hi...
I am making a power supply but stuck at transformer construction related issues. I already generated the schematic and Transformer construction parameters from PI Expert tool.
I am planning to make the transformer by hand at my home for my prototype. But few things are not cleared.
I am attaching the transformer construction guide. Please Find the attachment.
View attachment Transformer_Construction.pdf
My questions are:-
1. How to follow Winding direction? here showing clockwise, does this means rotating the wire clockwise or rotating the bobbin?
2. If I hold the bobbin as primary pins on my left, Should I change the orientation while winding the secondary side?
3. Primary winding will go from Left to Right, What about the Secondary winding, will it go from right to left without changing the bobbin orientation? My Bobbin is a Horizontal one.
4. How to check after making it? I have LCR meter, O-scope, DC power supply and function generator.
It's Showing Leakage Inductance of 8.56uH when all other pins are shorted, Is this means that all other windings except primary winding are shorted with a single wire at a single point or the 2 pins of bias winding shorted, 2 pins of secondary winding shorted(no shorted connection between bias short and secondary short)?
It will be a great help if someone provide step by step winding procedure with the information of orientation of bobbin.
Thanks and Regards,
SaV
My questions are:-
Thanks and Regards,
SaV
