eem2am
Banned
Hello,
These days, almost every single offline Flyback SMPS, PWM controller IC has the following functions built in to the chip……………
(1)…Auto-Restart (turns off if Vout doesn’t reach regulation value within ~ 80ms)
(2)…Overcurrent protection (current sense resaistor in source of FET)
(3)…Overvoltage protection (Senses bias winding voltage and turns off if too high)
(4)…Overload protection. (turns off if Vout goes out of regulation for more than
~80ms….similar to (1) )
Supposing I use an old PWM chip, such as UC3842.
…..the UC3842 has none of the above functions built in.
Will the resultant SMPS be illegal?…(not conforming to regulations)
Is it a regulatory requirement that an offline SMPS has the above four functions?
Do you know which regulation it is?
