I am not familiar with series chokes in power supplies, I've seen a low value series resistor before the capacitors to limit the inrush current.
If you get the datasheet for the MUR1560 and check the diode's ratings, then you can compare it with the power drawn by the expected/maximum load and check the peak impulse rating is much higher than you are expecting.
