smoothening filter for entopy error
snake0204
Newbie level 5
smoothing filter
Hi Everyone,
I have a question regarding smoothing an arbitrary signal. The signal is a entropy error rate which indicates the amount of information contained in dark and bright pixels in an image. The EER helps to find out the illumination in the scene.
The problem is the signal is constantly varying (coz of people moving in the scene), is there any way to smooth the signal using an adaptive filter or some kind of weighted average of previous N values and reduce the amount of variation.
I attached a Matlab plot of the signal.
Thanks
Snake
Re: smoothing filter
You could try low pass filtering to keep only the DC component.
If you do not want to implement digital filtering an alternative could be the use of a peak detector with opportune decay constant to partially rectify the signal:see the following example
#define DECAY 0x12345 // this value define the decay time in Q1.15 format
#define BUFFSIZE 12345 // buffer size used by the processing routine
static int peakEER
// processing loop
for( i=0; i< BUFFSIZE; i++ )
( ... ) // EER calculation (16 bit)
if ( EER > peakEER )
peakEER = sample;
else
peakEER = (peakEER * DECAY)>>15; // shift to restore 16 bit range
The key point is the DECAY value: it shall be chose to allow slow decay of the peak wrt the period of the expected lower frequency component of the signal.
The 2 methods could be also used in combination (filter and then rectify or viceversa).
Regards
Mowgli
Look at this:
https://www.dspguide.com/pdfbook.htm
... is there any way to smooth the signal using an adaptive filter or some kind of weighted average of previous N values and reduce the amount of variation.
See chapter 19 (single pole 4-stage)
There may be better filters for image processing though.
Thanks for the response!
cheers
snake
smoothing filter
get some info in opencore.org
