Jun 20, 2012 #1 J janne Member level 2 Joined Sep 9, 2003 Messages 49 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Location Sweden Activity points 328 I got a zener diod that are shorted in a power supply. I can find out the voltage of it, it's marked with PJ53 and KG, no hits then googling it..
Jun 20, 2012 #2 D davoud Full Member level 2 Joined Mar 10, 2005 Messages 146 Helped 39 Reputation 78 Reaction score 39 Trophy points 1,308 Activity points 2,119 maybe it is SMBJ6.0A **broken link removed** if you Share photo of your component then we can pursue it better. Last edited: Jun 20, 2012
Jun 21, 2012 #3 J janne Member level 2 Joined Sep 9, 2003 Messages 49 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Location Sweden Activity points 328 Seems to be correct, it's after a 5V feed from a PS or what do you think?
Jun 23, 2012 #4 D davoud Full Member level 2 Joined Mar 10, 2005 Messages 146 Helped 39 Reputation 78 Reaction score 39 Trophy points 1,308 Activity points 2,119 Yes , I agree with you.usually suppressors used for damping noise effects and surge. please check size of your component and compare with datasheet. And so this component placed in inverse direction like Zener. Regards. Davoud
