Jan 21, 2020 #1 F flamesier Newbie level 6 Joined Oct 2, 2010 Messages 13 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,453 hi all, im trying to replace this diode, but the marking is just mentioning as per attached image. could anyone please give me insight maybe based on previous experience what is the part number for this. really appreciate your help. First Line :2U Second Line : 55 thanks. Ram.
Jan 21, 2020 #2 W wwfeldman Advanced Member level 4 Joined Jan 25, 2019 Messages 1,101 Helped 231 Reputation 461 Reaction score 297 Trophy points 83 Activity points 8,554 there is this https://www.random-science-tools.com/electronics/SMD_markings.php and the surface mount codebook, a searchable 80 page pdf although i did not find 2u in either you might try searching a supplier, such as digikey or mouser for surface mount diodes if you know any other parameters, you can narrow the search you can get a comparable replacement if you know the voltage and current the diode should see.
