tonyctsiu
Member level 1
I am working on a project which uses a wind generator (basically a 10cm diameter windmill driving a motor as a generator giving AC current) to power a ~1W LED.
I would like to convert the AC power given by the generator in to DC.
Apart from using bridge rectifier which gives around 0.5-0.7V drop. Is there currently any sophisticated IC solution that can do the conversion with highest possible efficiency?
Regards
Tony Chun Tung Siu
Regards
Tony Chun Tung Siu
