do DC analysis, then choose print (from ADE window) DC parameters which will including capacitance of all the components connect to that node?
Added after 9 minutes:
or if you are running AC analysis, you can calculate acoording to V/I=a+jb, in which Im(V/I)=b=1/(sC).
By using calculator, current flowing into this node over the voltage of the net, then choose the imaginary part of the result, over 2*pi*frequency. frequency is the x vaule (xval).
you can get a plot of capacitance versus frequency.
