izua
Member level 3
hey guys!
i've been an amateur electronist for a while (working with a few ics, such as counters, and gates, but not all of them) and for a few days, i'm having this idea of using my programming skills in relation with my *few* electronic skills.
more exactly, i want to make a simple digital clock, controlled by the computer (or perhaps, a numerical display is a more adequate name).
i don't know exactly how should i do it. i believe i'll send a clock pulse from the computer, and 4 bits fed into a cmos 4511 (bcd to 7segment translator) ?
but how do i exactly send those 4 bits? does the serial port implementation allows for 5 bits at once (clock + 4 bits)?
or i should send the clock + another bit (i believe i can send at least two bits, right? ), and the circuit will count? like, first 4 bits go to the first 7-segment display, the second 4 (4-8) go to the second display? i believe the way our eyes perceive the flashing light will actually fake me into seeing the 4 digits lit up at all time.
i was also thinking if it's not better to send instead 7 bits. for a total of 4 digits, results 28 hertz per one full iteration of each segment, thus, perhaps a 50 hz "flash" rate will show it up as "permanent lit" (same effect of perceivment). so that's about 1,5khz, will the serial port support it?
thanks everyone - also, if anyone has any idea or suggestion, let me know.
regards,
izua
regards,
izua
