omara007
- Joined
- Jan 6, 2003
- Messages
- 1,237
- Helped
- 50
- Reputation
- 102
- Reaction score
- 16
- Trophy points
- 1,318
- Location
- Cairo/Egypt
- Activity points
- 9,716
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
-- Entity Declaration --------------------------------------------------------
entity rregfile_dp is
port (
clk : in std_logic;
rst_n : in std_logic;
-- Write Port -------------------------------------
-- Port-0
wr_en0 : in std_logic; -- Write Enable
addrs0_wr : in unsigned (rg_addrs_width-1 downto 0); -- Write Addresses
data0_wr : in signed (rg_data_width-1 downto 0); -- Write Data
-- Port-1
wr_en1 : in std_logic; -- Write Enable
addrs1_wr : in unsigned (rg_addrs_width-1 downto 0); -- Write Addresses
data1_wr : in signed (rg_data_width-1 downto 0); -- Write Data
-- Port-2
wr_en2 : in std_logic; -- Write Enable
addrs2_wr : in unsigned (rg_addrs_width-1 downto 0); -- Write Addresses
data2_wr : in signed (rg_data_width-1 downto 0); -- Write Data
-- Port-3
wr_en3 : in std_logic; -- Write Enable
addrs3_wr : in unsigned (rg_addrs_width-1 downto 0); -- Write Addresses
data3_wr : in signed (rg_data_width-1 downto 0); -- Write Data
-- Port-4
wr_en4 : in std_logic; -- Write Enable
addrs4_wr : in unsigned (rg_addrs_width-1 downto 0); -- Write Addresses
data4_wr : in signed (rg_data_width-1 downto 0); -- Write Data
-- Port-5
wr_en5 : in std_logic; -- Write Enable
addrs5_wr : in unsigned (rg_addrs_width-1 downto 0); -- Write Addresses
data5_wr : in signed (rg_data_width-1 downto 0); -- Write Data
-- Port-6
wr_en6 : in std_logic; -- Write Enable
addrs6_wr : in unsigned (rg_addrs_width-1 downto 0); -- Write Addresses
data6_wr : in signed (rg_data_width-1 downto 0); -- Write Data
-- Port-7
wr_en7 : in std_logic; -- Write Enable
addrs7_wr : in unsigned (rg_addrs_width-1 downto 0); -- Write Addresses
data7_wr : in signed (rg_data_width-1 downto 0); -- Write Data
-- Read Ports --------------------------------------
-- Port-0
addrs0_rd : in unsigned (rg_addrs_width-1 downto 0); -- Read Address
data0_rd : out signed (rg_data_width-1 downto 0); -- Read Data
-- Port-1
addrs1_rd : in unsigned (rg_addrs_width-1 downto 0); -- Read Address
data1_rd : out signed (rg_data_width-1 downto 0); -- Read Data
-- Port-2
addrs2_rd : in unsigned (rg_addrs_width-1 downto 0); -- Read Address
data2_rd : out signed (rg_data_width-1 downto 0); -- Read Data
-- Port-3
addrs3_rd : in unsigned (rg_addrs_width-1 downto 0); -- Read Address
data3_rd : out signed (rg_data_width-1 downto 0); -- Read Data
-- Port-4
addrs4_rd : in unsigned (rg_addrs_width-1 downto 0); -- Read Address
data4_rd : out signed (rg_data_width-1 downto 0); -- Read Data
-- Port-5
addrs5_rd : in unsigned (rg_addrs_width-1 downto 0); -- Read Address
data5_rd : out signed (rg_data_width-1 downto 0); -- Read Data
-- Port-6
addrs6_rd : in unsigned (rg_addrs_width-1 downto 0); -- Read Address
data6_rd : out signed (rg_data_width-1 downto 0); -- Read Data
-- Port-7
addrs7_rd : in unsigned (rg_addrs_width-1 downto 0); -- Read Address
data7_rd : out signed (rg_data_width-1 downto 0)); -- Read Data
end entity rregfile_dp;
-- End of Entity Declaration -------------------------------------------------
-- Architecture Declaration --------------------------------------------------
architecture rtl of rregfile_dp is
type regfile_type is array (natural range <>) of signed (rg_data_width-1 downto 0);
signal raccum_reg : regfile_type (0 to (2**rg_addrs_width)-1);
begin -- architecture rtl
-- Write Process
proc_wraccum: process (clk, rst_n) is
begin -- process proc_wraccum
if rst_n = '0' then -- asynchronous reset (active low)
raccum_reg <= (others => (others =>'0'));
elsif clk'event and clk = '1' then -- rising clock edge
if wr_en0 = '1' then
raccum_reg(to_integer(addrs0_wr)) <= data0_wr;
end if;
if wr_en1 = '1' then
raccum_reg(to_integer(addrs1_wr)) <= data1_wr;
end if;
if wr_en2 = '1' then
raccum_reg(to_integer(addrs2_wr)) <= data2_wr;
end if;
if wr_en3 = '1' then
raccum_reg(to_integer(addrs3_wr)) <= data3_wr;
end if;
if wr_en4 = '1' then
raccum_reg(to_integer(addrs4_wr)) <= data4_wr;
end if;
if wr_en5 = '1' then
raccum_reg(to_integer(addrs5_wr)) <= data5_wr;
end if;
if wr_en6 = '1' then
raccum_reg(to_integer(addrs6_wr)) <= data6_wr;
end if;
if wr_en7 = '1' then
raccum_reg(to_integer(addrs7_wr)) <= data7_wr;
end if;
end if;
end process proc_wraccum;
-- Read Process
data0_rd <= raccum_reg(to_integer(addrs0_rd));
data1_rd <= raccum_reg(to_integer(addrs1_rd));
data2_rd <= raccum_reg(to_integer(addrs2_rd));
data3_rd <= raccum_reg(to_integer(addrs3_rd));
data4_rd <= raccum_reg(to_integer(addrs4_rd));
data5_rd <= raccum_reg(to_integer(addrs5_rd));
data6_rd <= raccum_reg(to_integer(addrs6_rd));
data7_rd <= raccum_reg(to_integer(addrs7_rd));
end architecture rtl;
-- End of Architecture Declaration -------------------------------------------
omara007 said:I am trying to map my vhdl coded memory into Xilinx distributed RAM .. I'm using Xilinx Spartan-3A DSP chip (XC3SD1800A-4fg676) and Xilinx ISE 11.3.
I'm facing 2 problem:
1. Synthesis using XST is taking too long .. approximately 5.5 hours.
2. The chip utilization of just the memory is 47% of 1.8 million-gate equivalent chip.
shitansh said:I had written code of SRAM in verilog using two dimensional array, and this way for small RAM code synthesis time and core utilization was too much, for me also!!
The proble with two dimensional array for me in Actel tool, I change code and it was working fine for me and problem solved.
omara007 said:how did you manage to solve it (with code examples if possible) ..
palai_santosh said:whats the value of "rg_data_width" & "rg_data_width"?
shitansh said:omara007 said:how did you manage to solve it (with code examples if possible) ..
Please find two files in attachment.
Please note that these files are provided just to give reference to you.
while synthesizing SramCtrl.v core utilization and syntesis time are too much.
And while synthesizing SramCtrl_modified.v, there is less syntesis time and also core utilization is also reduced.
For me problem was due to two dimensional array and seperate clock for read and write.
Just try to syntesis these files in your tool
HTH
Shitansh Vaghela
palai_santosh said:----------------------------------------------------------
-- Write Process
variable Wen_sel : std_logic_vector(7 downto 0);
Wen_sel:=wr_en0 & wr_en1 & wr_en2 & wr_en3 & wr_en4 & wr_en5 & wr_en6 & wr_en7;
case (Wen_sel) is
when "10000000" => raccum_reg(to_integer(addrs0_wr)) <= data0_wr;
when "01000000" => raccum_reg(to_integer(addrs1_wr)) <= data1_wr;
when "00100000" => raccum_reg(to_integer(addrs2_wr)) <= data2_wr;
when "00010000" => raccum_reg(to_integer(addrs3_wr)) <= data3_wr;
when "00001000" => raccum_reg(to_integer(addrs4_wr)) <= data4_wr;
when "00000100" => raccum_reg(to_integer(addrs5_wr)) <= data5_wr;
when "00000010" => raccum_reg(to_integer(addrs6_wr)) <= data6_wr;
when "00000001" => raccum_reg(to_integer(addrs7_wr)) <= data7_wr;
when others => raccum_reg <= raccum_reg;
end case;
end if;
