firsttimedesigning
Full Member level 1
So I have designed an Op-Amp that has a gain of 80dB and its phase margin is about 45 degrees so it is stable. the problem is that when i hooked it up with a capacitor and resistor to make it operate as an integrator, it always has this small bump at the beginning. When the input voltage is changed at 500ns it also has another bump (please see attached file). I know this bump has to do with the capacitor that is connected at the output. is there anyway to eliminate this bump?
any suggestion is welcome. thank you
