Apr 1, 2009 #1 S signalfethut Newbie level 3 Joined Sep 8, 2008 Messages 3 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,297 slot in patch antenna i don't why addition a slot on patch antenna can compressing scattering parametter S11. Can you help me explain this problem ?
Apr 1, 2009 #2 V vfone Advanced Member level 6 Joined Oct 10, 2001 Messages 5,709 Helped 1,616 Reputation 3,237 Reaction score 1,248 Trophy points 1,393 Activity points 36,250 Re: slot in patch antenna The patch itself provides one resonant point and the slot is another resonant point. The slot forces current to flow in a different path on the patch and each path of current flow corresponds to a resonant point. So, S11 will change.
Apr 2, 2009 #3 M mainak001 Member level 3 Joined Dec 1, 2005 Messages 60 Helped 4 Reputation 8 Reaction score 3 Trophy points 1,288 Location India Activity points 1,632 Re: slot in patch antenna Slot is generally applied for Broadbanding the response .. all uWB applications have slot ..So u can use slot in microstrip along with cpw feed .... With little tuning ur S11 will also be gr8
