Hello,
I have a question about slew rates and slew rate limiting.
Is I measure the slew rate for an opamp - say positive and negative, and I also measure the maximum rate of change at the output of the opamp.
If the value of the maximum change of the output of the opamp is greater than the slew rates positive and negative (single ended output) - then I dont get slew rate limiting OR is it less than the positive and negative slew rates ?
Where is this explain, what text ?
Thank you.
