i found this answer in synopsys's site. hope it clarifies ur query.
Clarification on the Value to Be Specified for slew_derate_from_library
Question:
In a library that an intellectual property (IP) vendor gave us, the trip points
were specified as 30 - 70, with a slew-derating value of 0.5. The vendor tells
us that the cells were in fact characterized at 30 - 70 but were extrapolated
to 10 - 90 (that is, they used their own formula to calculate 10 - 90 slew
rates from their measured 30 - 70 numbers). The final extrapolated values were
placed in the lookup tables.
This doesn't look right to me because the cells were effectively characterized
10 - 90, so why not use 10 - 90 as trip points and slew_derate = 1 in the
header? I'm worried that the derating value will cause the final slew to be
derated twice in the end--once from when the vendor extrapolated and another
time by PrimeTime. Am I right to be concerned?
Answer:
The data given to you by the IP vendor is quite common for deep submicron
designs, which have a linear region between 30 and 70. So, if the vendor
characterized the cells as 30 - 70 and extrapolated to 10 - 90, the slew_derate
value that should be specified in the library is calculated as
slew_derate = (70 - 30)/(90 - 10) = 40/80 = 0.5
Your understanding that the final slew will be derated twice is not correct.
When the library contains slew trip points of 30 - 70 and a slew_derate value
of 0.5, PrimeTime will be able to calculate that the cells were characterized
as 30 - 70 and extrapolated to 10 - 90. If the vendor accidentally specified
the slew trip points as 10 - 90 and slew_derate = 0.5, that would indeed be a
problem, and PrimeTime would no longer be able to do correct slew calculations.
Setting trip points as 10 - 90 and slew_derate = 1.0 would work, but accuracy
would be lost, and the tool might generate an RC-004 warning because of that
inaccuracy.
For the most accurate calculations from PrimeTime, the library should specify
the slew trip points as 30 - 70 and slew_derate as 0.5. Setting the slew trip
points as 10 - 90 with slew_derate = 0.5 would be totally wrong in this
characterization situation.
So what the library vendor has done is correct.
