Le
Member level 1
Hi All,
I got some problems on size of coaxial wave port.
Since i am simulated planar antenna which i am using wave port to be touched with my feed point of antenna, although the result of simulation shows me a good size, however, i wondered how large the coaxial wave port should i use. 1mm diameter internal core? 2mm diameter in vaccum ground shielding? or as long as i set it as 50ohm for all freq no matter how small we make it into HFSS if and only if it can touch the antenna feed?
I would like to have some advice on it.
Best Regards,
Le
Best Regards,
Le
