+/- sinusoid from AD9850 DDS chip.
zoulzubazz
Member level 5
Member level 5
hey,
the requirement is to generate a sinusoid about +/-1V peak to peak somewhere close to 10MHz. The AD9850 DDS chip can be used to achieve this frequency but can output only dc and upwards. Is there a way to transform the output from the DDS to a sinusoid split between + and - voltage. thanks very much.
thanks FvM, the ability of a cap to block DC is sort of the fundamentals. simulated this in spice and it works. this might sound daft but I don't understand the physics behind it though, how can a cap source a voltage below ground.
A capacitor cannot pass DC, thus any signal through a capacitor must have an average DC value of 0V. This means any sinewave through a capacitor will be centered around 0V with equal plus and minus peaks to give a 0V average value.
Since above ground (+) and below ground (-) are just voltages relative to ground a capacitor output can readily go either way. There's nothing special about "below ground" as compared to "above ground" to a capacitor.
Reactions: David_
    David_
