ballimo
Member level 3
- Joined
- Jun 30, 2008
- Messages
- 64
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Activity points
- 1,776
Hello ALL,
I am using a Single side stable Relay "TX2-12V" From Panasonic ; The datasheet shows the Direction indication as : (+) for pin 1 and (-) for pin 12 , (Deenergized condition); Please check snapshot above.
The nominal coil voltage is 12V, should I connect 12V to pin 1 and ground to pin 12? what confuse me is the "Deenergized condition" note, does this coil change polarity in the energized condition?
Thank you in advance,
Ballimo
Ballimo
