Single Phase Input and output VFD
AsadZero2
Newbie level 1
Newbie level 1
Contrary to all the arguments against one, my team has accomplished a variable frequency drive (3-level inverter H-bridge) on fundamental PWM.
The problem arose when we opted to make a 5-level inverter. The code that we made on arduino UNO on each pin should generate a 50Hz signal. It is generating a gate signal of 50Hz on proteus when i use Barebone-Uno but when i test the code Irl, the frequencies are way off.
This is the code:
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
void setup();
void loop();
void setup() {
pinMode(1, OUTPUT);
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
pinMode(7, OUTPUT);
pinMode(8, OUTPUT);
void loop() {
//1)
digitalWrite(1, HIGH);
digitalWrite(2, LOW);
digitalWrite(3, HIGH);
digitalWrite(4, LOW);
digitalWrite(5, LOW);
digitalWrite(6, HIGH);
digitalWrite(7, LOW);
digitalWrite(8, HIGH);
delayMicroseconds(1250);
//2)
digitalWrite(2, HIGH);
digitalWrite(6, LOW);
//3)
digitalWrite(3, LOW);
digitalWrite(7, HIGH);
//4)
digitalWrite(4, HIGH);
digitalWrite(8, LOW);
//5)
digitalWrite(1, LOW);
digitalWrite(5, HIGH);
//6)
//7)
//8)
//9)
//10)
//11)
//12)
//13)
//14)
//15)
//16)
Its been designed to work on 20ms, i.e. 50Hz.
I'd appreciate any help i can get. Thanks
Asad Ali Kha
