Single ended to differential in transimpedance amplifier
timedate
Member level 5
Member level 5
germany
Hi, all
Does anybody know how to play a single ended to differential conversion in the transimpedance amplifier ?
Just like the red circle in the Figure.
My input analog signal is 50MHz, amplitude is about very low, about 1mV.
So, should I use a balun or fully differential amplifier like the following circuit?
I have seen the same post two days ago. Did you delete the old thread and started it anew? The first image has been already uploaded on monday...
Why not use a balun?
could you plz give me a hint how to delete a thread in edaboard, I searched but could not find it.
could balun deal with this very low input signal (small than 1mV) ?
Why it shouldn't? It depends on what you want. After balun you can amplifier your signal and so on.
