Devavrat
Newbie level 1
Hey guys,
I need help with my FYP. Im trying to make an accelerometer based mouse using a single 3 axis accelerometer(MMA7260). Ive chosen ATmega16 as my microcontroller. I've got two options of either using CVAVR or AVR Studio 4 as my compilers and have Ponyprog2000 as my programmer. My development board is from Thinnkware.
Here are some of the problems im facing :
1) The code for the project is written for CVAVR but even if i execute a simple loop(for,while,etc) to flash LEDs in CVAVR,it does not run on the development board. I do not know how to program using AVR studio 4 (dont know the functions or header files)
2) I need to send the signals to the PC via PS/2 protocol. Ive obtained a PS/2 wire from an old mouse but am not sure how to interface it with a microcontroller. Do i directly connect it to any port of the uC and program that port to send bytes of data? or do i send the data from the uC first to a voltage converter like MAX232 and then send the Txd values to the PS/2 pins? because when i opened up my optical mouse, i saw a small 16 pin uC soldered onboard.
3)My 3 axis accelerometer has mode selection for various values of sensitivity(1.5G,2G,4G,6G). I want to know which value should i go for when i test my project - high sensitivity(1.5G) or low sensitivity(6G). Also what is the difference between dynamic acceleration and static acceleration? do i need to set sensitivity values for both these modes??
Any help in the above matter will be highly appreciated. Please help. Thnx
Devavrat
P.S. Code for CVAVR prog attachedView attachment air mouse code.txt
Devavrat
