koolchiq
Can someone help me with a working circuit for my problem. i want to design and implement the output stage of an inverter. I used discrete components for the PWM stage. I am getting 20 v p-p from my LM319 comparator (50Hz sine wave and triangular wave IN). My problem is how do i implement the output stage from here. i have 2 buz11 mosfets and 1 TIP 2955/3055 complimentary pair BJT's. Output not to exceed 30v ac and 1 amp @ 50 Hz. Can i use the BJT's to drive the mosfets or vice-versa? If so ho do i configure the circuit? Please help.
Thank you.
Thank you.
