it is not a mechanical generator.....i have to give this sine wave into a sine wave amplifier!! only requirement is 50 hz frequency!! 5 volt dc voltage is the input to be given from a micro controller...!! what should i do??
DXnewcastle gave you already some interesting hints.
One additional recommendation from my side:
At first, read some related sections in textbooks in order to understand the principle of sinusoidal oscillators - in particular, why a "linear/harmonic" oscillator must contain one non-linear element for amplitude stabilization.
There are 3 ways to achieve this. Read Carefully .
1) By using the BIP Sine Wave Generator. It's a freeware and is just 117 Kb in size. You have to take the output from the 3.5mm miniature jack. (it's speaker-out pin I'm referring to).
Specks :
Sampling frequency:
The oscillator automatically uses the highest sample frequency available at the output that you select (usually maximal 44 kHz but people with 22 kHz max. also use the generator without any problems).
Output impedance:
The same as the output impedance of your sound card. Normally the output of a sound card is very low (which is good) in order to be able to connect a speaker (which is not needed for this application).
Accuracy:
The generator uses 8-bit samples to generate the sine wave signal. The sine wave is created using a secret algorithm which makes use of special floating point instructions of your microprocessor.
[or]
2) By using signal generator of soundcard scope software v1.32 (shareware)
[OR]
3) By using Matlab Function Generator Tool. [should have matlab installed]
Please add my reputation by clicking [star symbol below] if you find the reply useful!! thanks!! [thumbs - up] :roll: :-o
STEPS:
1) PLAY THE FILE IN ANY AUDIO PLAYER IN SYSTEM
2) PLUG THE 3.5 mm JACK (IT HAS FOUR O/P WIRES left speaker, right speaker, antenna, ground (NORMALLY)
3) GET THE OUTPUT FROM left/ right speaker wire and ground wire
4)THAT'S ALL
I'm giving this idea because 50 Hz is low freq and has to be generated accurately.
also
there is no circuit involved. so it's quite easy.
You personally are using this oscillator topology. Is that the only reason for your recommendation?
In contrary to you, I don`t think "it's very simple and easy".
It needs 4 opamps and 10 passive elements. It`s main advantage - if compared with other circuits - is the capability to provide two quadrature signals (out of phase by 90 deg). However, if this feature is not needed, there is no good reason to use the BUBBA type.
For example, the well known WIEN type uses only one opoamp and 4 passive elements. I think, this or a similar type is most appropriate for 50 Hz.
I must agree that the Wein Bridge Oscillator is probably the most appropriate for the OP's requirements - I certainly agree that its complexity is no more than what is necessary.
I have some of these working perfectly after many years of use. There are many circuits available from a simple Google search, including variations for ultra-low distortion and for variable frequency; they would provide much lower distortion than any computer-generated sine generator.
My only word of caution would be to check if an output buffer may be required, as the simplest designs can behave unexpectedly with certain loads.
