I am searching a Chip that can generate a Sine or Square or Triangle wave( in other word I can select the output to be Sine, Square or Triangle).
If anyone has used such an Chip Please send me the Manufacturer part number or the data sheet.
I want a high frequency chip up to 100 MHz, I did not find any. the Maximum Frequency I find is 20 MHz (MAX038) and it is obsolete.
do you have any idea if a 100 MHz Chip can be found? it seems that all these part are obsolete, is this a coincidence or is there a reason?
I assume you're right, because neither said AD9851 nor other DDS chips, I'm aware of, have a triangle waveform output option.
But I may have missed it.
