What is the correct process of development from a Simulink model to a C6713DSK?
1. Build model using normal Simulink blockset and Signal Processing blockset
2. Generate C code using Real-Time Workshop for Code Composer Studio and Embedded Target for C6000
3. Compile code in CCS
is this correct?
Because i always though that the so called Embedded Target for C6000 itself contains signal processing blocksets specifically for TI C6xxx DSPs and if i want to generate C code for TI DSPs i should build using blocks in Embedded Target for C6000.
Well yes a lot of people has problems because .The installation is somehow bad .And MATLAB can't find the Ti compilers ,. Be shure to have all the system variables in order .
RelTime workshop produces the c code from the Simulink model equivalents and calls the compilers to get you a binary .
Be sure to set all configuration parameters and system target file especially. If the target file in Config is not set correctly, you wont be able to download .out file!
