Simulation Problem On @DS
fangll
Junior Member level 2
I have installed @DS 2002C and run under float license. i can start the software and load design, such as integrator example under ../example/tutitor directory, but if open the project and run the simulation command from the menu, the message display "can not load sdfstars".
Is there any setting need run the simulation?
you can try to copy it toyour work directory and to do what you want.
