Simulation on time drift impairment
babyeric
Junior Member level 1
When there is a different in clock frequency between the transmitter and receiver. There will be a time drift occurs other than frequency offset. I need to emulate this time drift. I try to use function resample, however, the range is not within the limit that I want to emulate. For eg, the ratio between my transmitter and receiver clock frequency is 1/1000000, so I use resample(x,1000000,1000001), where x is my data. Matlab prompt error due to the size of p (1000000) and q(1000001) exceed 2^31.
Anyone has a better method to emulate timing drift? Hope to get help from you guys.
Thank you.
