Hi all
I want to simulate a substrate integrated waveguide (SIW) with and without microstrip taper to get the same results. What is the correct size of the waveport excitation for the SIW (I guess I will use "Zpi" under the characteristic impedance (Zo) column or maybe "Zwave")? should it be exactly between the two rows of vias or larger?
Also, for the second case (i.e., with microstrip taper), the waveport size should be now based on the microstrip line (i.e., ~5*w * >4h)?
I want to make sure the microstrip taper will not affect my S11 and S12 results.
Thanks.=!
