Rakel Zobaer
Newbie level 2
I have tried to design a Pickett Potter Horn Antenna with Ansoft HFSS. When i get the lambda for 8.7GHz and select the solution frequency also 8.7GHz than always shown error messages:
1. Fast sweep setup.process hf3d error: Matrix solver exception: out of memory.
2. Simulation Completed with execution error on server: Local machine.
But, if i get the lambda from 8.7GHz and select the solution frequency is 6GHz than the software simulate successfully. What can i do for that?
Is this is the problem for Mesh size? If it is problem for mesh size than how can i select the mesh size? Also how can configure the mesh size?
