I am using Spectre RF in Cadence. I have the following question:
In a PLL the control voltage that comes form the charge pump (even after filtered by the Loop filter), it is not stable but has some ripple with a period equal to the reference frequency (50MHz in my case). From simulations that i have done on a charge pump that i have designed, the control voltage has a triangle shape with a ripple of 2-4mv.
What i want to investigate, is the effect of that ripple on the VCO, and more specifically on the phase noise and the output spectrum.
If i set the control voltage of the VCO as a triangle voltage source with F=50MHz)and perform the PSS analysis, i get the following message "V0 is a periodic input signal , which is inconsistent with autonomus system"
What am i doing wrong?
