Simulating Balun in ADS Schematic
sprasv
I am trying to do this circuit in ADS Schematic. I have been able to find all other components. But I have not been able to find this
"3 port Balun which says Balun_device". I did find other 3 port baluns, but I would like to know under which list it will be possible to find this component.
"balun_device" I have attached the schematic.
Please help me, as I have been stuck at this point. I would deeply appreciate it.
Thanks,
Prasanna
It is a custom component.
Select this instance and then do "identify" from menu.
Can you explain more? I would greatly appreciate it if someone explains and tells me how to simulate what is in the schematic.
Thanks for replying,
Prasanna
---------- Post added at 20:37 ---------- Previous post was at 20:26 ----------
This schematic is on paper. I dont have a soft copy of the ADS program. Its from a thesis I am trying to implement.
Yes,
I am new to ADS. I did find the link you posted on the agilent website.
But is there a way, I can recreate the exact component as in the picture as in an exact way of simulating the custom component.
Thanks,
Prasanna
Prasanna
that balun device is a subcircuit: inside that block there is another schematic and you cannot know from a paper what is inside.
Googling your infos, I've found this thesis:X-band Phase Shifters for Phased Array, Jean Xu, cincinnati university. Is it the one you are trying to implement, I guess.
The schematic of the balun is done using 2 lange couplers, see page 38.
I hope it can help.
Mazz
Hi Mazz,
Thanks a lot, that explains it in detail.
Yeah I have downloaded that Thesis document and did see the schematic. So my understanding is that the "sub-circuit" inside this "custom component" is the schematic given in page no. 38.
Since I am new to ADS, i did not quite understand it.Thanks again.
How do i make my own custom component in ADS? Will it be possible for you to explain that?
Thanks,
Prasanna
Prasanna
I hope it can help.
Mazz
---------- Post added at 22:49 ---------- Previous post was at 22:48 ----------
I am sorry but I am not really sure what that question means..
Prasanna
Prasanna
you don't really need to do a subcircuit. You can place the balun at the same level of the rest of the circuit, if this is easier for you.
Mazz
Reactions: sprasv
    sprasv
