Recently I use ADS Simulate Loop- PCB antenna, and it’s frequency is 13.56Mhz. Acturally I use Vect Network Analyser to measure this antenna’s inductor value is 1.6uH, but now when I simulate it in ADS, it is very different with acturally result.
PCB Antenna Picture
Port1 Setting
Port2 Setting
Substrate setting
Layout Layers Setting
Mesh Setting
Simulation Setting
Simulation result
Actual measure result S11 of the pcb antenna
From the simulation result, we know this impedence is 50*(4.02E-8 + 0.068j), it’s equivalent circuit is a resistor series a inductor, the resistor’s value is 50×4.02E-8, and the inductive reactance is 50×0.068 = 3.4 = jwL = 2*3.14*13.56 E6 => L= 0.0399uH, but I use Vect Network Analyser to measure this antenna’s inductor value is 1.6uH, so why ?
RFID coil is effectively a pure AC magnetic problem that don't need a full featured EM solver. Nevertheless should it give correct results. I read about a cellsize setting of 20 cells/wavelength, which refers to a cell size of about 1.1 m. Don't know if this is a problem.
Hello everybody!
This problem is solved, the real size of the antenna is 180mm * 180mm, but the layout is 180mil * 180mil, so it is wrong. When I change the scale , the simulate result is very close to the true result. Select the layout then chose edit-》 scale.
