Simply question about the ASM (INT0), Please help~!
johnny01hk
Junior Member level 1
I want to add the INT0 into my program,
When the INT have Logic 0 input,then the progarm will auto jump to Z,
also stop before working process.
But I don't know how to add that function on my progarm.
And I don't know hot to setting the other point.
For example the IT0, EA, EX0,
Who can help me write a command and setting into my progarm?
ORG 00H
JMP START
ORG 100h
START:
SETB P2.0 ;Motion detector Input
SETB P2.1 ;Metal detector Input
CLR P1.0
CLR P1.1
Loop:
JNB P2.0, X
JNB P2.1, Z
SJMP Loop
X:
SETB P1.0
CLR P1.1
LCALL Delay ;Call Delay
CLR P1.0
CLR P1.1
SJMP START
Z:
SETB P1.1
CLR P1.0
CLR P1.0
CLR P1.1
SJMP START
Delay:
MOV R2, #50 ;~1s
S1:
MOV R3, #200
S2:
MOV R4, #200
DJNZ R4, $
DJNZ R3, S2
DJNZ R2, S1
RET
END
It may not be the final version but at least will give you an idea on how to use and acitvate Int0 ..
$NOPAGING
$MOD252
;BIT  PSW.1 is used as general purpose flag ..
ORG		0000H
LJMP		START
ORG		0003h
LJMP		ExtInt0		; External interrupt 0 ..
ORG 0100h
START:
SETB		TCON.0		; Int0 active at the edge..
SETB		IE.7			; General interrupt active..
SETB		IE.0			; Int0 is enabled..
START2:
; Metal detector to be connected to /INT0 .. SETB P2.1 - Metal detector Input
CLR P1.0
CLR P1.1
Loop:
JNB P2.0, X
;			JNB P2.1, Z
JB	PSW.1, Z
SJMP Loop
X:
SETB P1.0
CLR P1.1
CLR P1.0
CLR P1.1
SJMP START2
Z:
CLR	PSW.1		; Clear flag ..
SETB P1.1
CLR P1.0
CLR P1.0
CLR P1.1
SJMP START2
Delay:
MOV R2, #50 ;~1s
S1:
MOV R3, #200
S2:
MOV R4, #200
S3:
JB	PSW.1, Del_Exit	; If interrupt occured exit delay ..
DJNZ R4, S3
DJNZ R3, S2
DJNZ R2, S1
Del_Exit:
RET
ExtInt0:
SETB		PSW.1		; set flag on interrupt ..
RETI
END
IanP
:D
    johnny01hk
$NOPAGING
$MOD252
ORG		0000H
LJMP		START
ORG		0003h
ORG 0100h
START:
START2:
CLR P1.0
CLR P1.1
Loop:
JNB P2.0, X
;			JNB P2.1, Z
JB	PSW.1, Z
SJMP Loop
X:
SETB P1.0
CLR P1.1
CLR P1.0
CLR P1.1
SJMP START2
Z:
SETB P1.1
CLR P1.0
CLR P1.0
CLR P1.1
SJMP START2
Delay:
MOV R2, #50 ;~1s
S1:
MOV R3, #200
S2:
MOV R4, #200
S3:
DJNZ R4, S3
DJNZ R3, S2
DJNZ R2, S1
Del_Exit:
RET
ExtInt0:
RETI
END
IanP
:D
Thx so much~~!
