dwluv3333
Newbie level 2
Have a question regarding spectrum analyzer and RBW setting...
On a spectrum analyzer, say you have a signal at 1 GHz and your resolution bandwidth is 300 kHz. If you use the 'marker' function and put the marker at 1 GHz, and it says -50 dBm, what exactly does this mean? Does it mean that the power in a bandwidth located at 1 GHz within a 300 kHz bandwidth (or, equivalently, 1 GHz +/- 150 kHz) is -30 dBm?
Also, I've heard that if you want to do an accurate power measurement of a signal, you need to set the RBW to the same bandwidth as the signal (so a 3.84 MHz WCDMA signal needs to have an RBW set to 3.84 MHz, etc). Is this true? I'm having a hard time understanding why the RBW isn't always best when set to its lowest possible value.
Thanks everyone in advance for your advice and help!!!!
