qasmi
Member level 3
Hello all,
I have some questions regarding Layer and Planes, I hope you will patient to read them and then answer them with patience.
1. I have designed a digital board with 6 internal layers and 2 power planes. I've further splited the Power Plane into 5 Power supplies. and the ground plane into Analog and Digital. The highest frequence of my board is till 20 MhZ. My question is, My Layer Stack is
TOP-signal--signal--signal-VCCPLANE--GROUNDPLANE--signal-signal-signal-bottom
Is the above Layer Stack recommended or any suggestions.
2. Now I'm designing the Power Module which will go into the above mentioned Digital Board. This Module will supply 3 seperate voltage supplies for FPGA, a VCC3.3V and VCC1.8 volts for the overall system. AS I have mentioned above that I've splitted the POWER PLANE of the Digital board for these voltages to go into it. My question is, IS it recommended that I insert a PLANE for each of the Power Supply in my POWER module Board.
Thank you, and take care
Best Regards
Best Regards
