simple program with 12F629
deniah
Member level 4
Montenegro
12f629 simple
Hello
I need som help with this program.
It should work like this: when power on, GPIO.2 is high. When apply HI on GPIO.0, after 3 sec GPIO.2 should be low.
Config is mclr=off, pwrt=on, wdte=on,boren=on, int OSC I/O.
I'm using Microcode studio with PicBasic Pro compiler
Here is the code
CMCON=7
ul var GPIO.0 'Define GPIO.0 pin as ul
izl VAR GPIO.2 'Define GPIO.2 pin as izl
High izl
Input ul
loop:
if ul=1 then
pause 3000
low izl
end if
goto loop
set osc 12f629
i think you should set WDT off. otherwise the pic will get rest at the middle of the program. OR you should issue the CLRWDT to clear wdt to ensure no reset due to WDT overflow.
