Swend
Full Member level 4
- Joined
- May 14, 2019
- Messages
- 237
- Helped
- 10
- Reputation
- 20
- Reaction score
- 9
- Trophy points
- 18
- Location
- Roskilde, Denmark
- Activity points
- 2,304
Hi Friends,
I've got this simple power supply with clean sinusoidal input, but after the bridge rectifier some noise is introduced and I have no idea why, maybe you have some suggestions?
As you can see on the left there is a bog standard ZVS driver running at about 40KHz and two secondary windings with bridge rectifier and a smoothing cap on the output..
Here is the output of the secondary winding
Here is the output noise of the positive side
Here is a closer look at the peak noise
