D'Crex
Newbie level 6
Hello,
I want to make a simple NPN transistor based adder, but have a problem with how to begin. There are many circuits around, but some are using diodes on the emitters (sink current prevention), some don't. Some are using pull down resistors on the base other's don't. Then there is another thing when some are using resistor on collector.
What would be the best way to connect an npn switch? Should I always use diodes and pull down resistor? (on each of the transistors)
Thank you
Thank you
